Go to main content
Oracle® Exadata Storage Server X5-2 Extreme Flash Service Manual
Exit Print View
Updated: January 2018
Configure TPM Support
If you intend to use the Trusted Platform Module (TPM) feature set, you must configure the server to support this feature.
Note -  TPM enables you to administer the TPM security hardware in your server. For additional information about implementing this feature, refer to the Windows Trusted Platform Module Management documentation provided by your operating system or third-party software vendor.
  1. Access the BIOS Setup Utility menus.
    See Access BIOS Setup Utility Menus.
  2. In the BIOS Setup Utility menus, navigate to the Advanced Menu.
    The Advanced Menu screen appears.
  3. In the Advanced Menu screen, select Trusted Computing.
    The TPM Configuration screen appears.
    image:This figure shows the TPM Configuration screen in the Advanced                         Menu.
  4. TPM Support is listed as Disabled (it is disabled by default). Select TPM Support and press Enter.
    A TPM Support dialog box appears.
    image:This figure shows the TPM Support dialog.
  5. In the dialog box, set TPM Support to Enable, and then press Enter.
    The updated TPM Configuration screen appears.
    image:This figure shows the TPM Configuration screen with TPM support                         enabled.
  6. Press the F10 key to save the changes and exit the BIOS Setup Utility.
Related Information
