If the storage server is in the extended maintenance position, use this procedure to return the storage server to the normal rack position.
As you push the storage server into the rack, verify that the cable management arm (CMA) retracts without binding.
You will hear an audible click when the storage server is in the normal rack position.
For installation instructions for the CMA, refer to Install the Cable Management Arm in Oracle Exadata Storage Server X5-2 Extreme Flash Installation Guide.
For instructions on reconnecting cables to the rear of the storage server, see Reconnect Power and Data Cables.
For detailed information on connecting cables to the rear of the storage server, see Rear Panel Connector Locations.
