The TLS v1.2 encryption configuration property is enabled by default in newer Oracle ILOM firmware releases . Use the following procedure to view or modify the web server security properties in Oracle ILOM.
Before You Begin
Admin (a) role is required to modify the web server properties in Oracle ILOM.
The default setting for the TLS protocol properties in Oracle ILOM is dependent on the firmware version that is currently installed on the managed device. For instance:
TLS v1.0 service is disabled by default in Oracle ILOM 3.2.9. Support for the TLS v1.0 service is removed in Oracle ILOM as of firmware version 4.0.0.
TLS v1.1 service is disabled by default in Oracle ILOM 4.0.4.
TLS v1.2 service is enabled by default in Oracle ILOM 3.2.8 and later.
To view or modify the web server security properties in Oracle ILOM, refer to the following web-based instructions.
For further details, click the More details... link located at the top of the Management Access -> Web Server page.
Web Server Configuration Properties, Oracle ILOM Administrator's Guide for Configuration and Maintenance (Firmware 3.2.x)
Web Server Configuration Properties, Oracle ILOM 3.1 Configuration and Maintenance Guide
