Go to main content
Oracle® ILOM Security Guide For Firmware Releases 3.x and 4.x
Exit Print View
Updated: December 2019
Security Checklist for Server Deployment
To determine which Oracle ILOM security practices might be best when planning the deployment of a new server, system administrators should consult the list of security tasks recommended in the following Figure 1, Table 1, Checklist - Configuring Oracle ILOM Security at Server Deployment .
Table 1  Checklist - Configuring Oracle ILOM Security at Server Deployment
Security Task
Applicable Firmware Version(s)
For details, see:
Establish a secure dedicated management connection to Oracle ILOM.
All firmware versions
Decide whether FIPS 140-2 security compliance is required at or after deployment; or, not at all.
Firmware versions 3.2.4 and later
Set Password Policy for All Local User Accounts
Firmware version 3.2.5 and later
Modify the default password provided for the preconfigured Administrator root account.
Decide whether the preconfigured Oracle ILOM services and their open network ports are applicable for your target environment.
Configure user access to Oracle ILOM.
Decide whether access to the host operating system should be locked upon exiting a remote KVMS session.
Firmware versions 3.0.4 and later
Decide whether to limit other SP users from viewing remote KVMS sessions launched from the SP.
Decide whether to display a security banner message at user login or immediately following user login.
Firmware versions 3.0.8 and later
Ensure that the proper security properties are set for all Oracle ILOM user interfaces.
For ASR Client configurations, choose to keep the preinstalled SSL Certificate or upload a user-specified SSL Certificate.
Firmware versions 4.0.x and later.
Ensure that the servicetagprotocol is properly configured to use HTTPS and a passphrase.
