You can redirect the system console to a local graphic monitor. You cannot use a local graphics monitor to perform the initial server installation, nor can you use a local graphics monitor to view POST messages.
Tighten the thumbscrews to secure the connection. Refer to the server's installation guide for any special connection instructions that might apply to the server.
ok setenv input-device keyboard ok setenv output-device screen
ok reset-all
The server stores the parameter changes and boots automatically.
You can now type system commands and view system messages using your local graphics monitor. To activate the GUI interface, continue to the next step.
Once Oracle Solaris is installed and booted, type the following commands to display the GUI login screen:
# ln -s /dev/fbs/mga0 /dev/fb # fbconfig -xserver Xorg # reboot
