SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
OpenBoot Prompt
When the host is powered on but the OS is not booted, you communicate with the OpenBoot firmware. OpenBoot firmware displays ok as its prompt.
This table lists the common tasks that are performed at the ok prompt:
Task
For More Information
Boot the host.
Configure OpenBoot parameters.
Run diagnostics.
Refer to detecting and managing faults in the service manual for the server.
Reset and power off the host.
At the OpenBoot prompt, type help reset to display details about the reset command.
Eject media.
At the OpenBoot prompt, type help eject to display details about the eject command.
For more details about OpenBoot, refer to the OpenBoot 4.x Command Reference Manual at:
http://docs.oracle.com/cd/E23824_01
Locate the document under Important Information From Previous Releases.
Related Information
