SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Shut Down the OS (init Command)
The init command is an executable shell script that terminates all active processes on a system and then synchronizes the disks before changing run levels. Specifying run level 0 shuts down the OS and displays the OpenBoot prompt.
  1. Log in to Oracle Solaris as a user with root privileges.
  2. Shut down the OS.
    Note - This document applies to several server and server module products. The following example is based on the SPARC T5-1B server module. Your output might vary from the examples based on your product.
    # init 0
    # svc.startd: The system is coming down.  Please wait.
    svc.startd: 126 system services are now being stopped.
    Sep 21 13:31:31 systemA.xxxxx.com syslogd: going down on signal 15
    svc.startd: Killing user processes.
    Sep 21 13:31:37 The system is down.  Shutdown took 23 seconds.
    syncing file systems... done
    Program terminated
    SUN BLADE 6000 MODULAR SYSTEM / SPARC T5-1B, No Keyboard
    Copyright (c) 1998, 2012, Oracle and/or its affiliates. All rights reserved.
    OpenBoot 4.35. 63 GB memory available, Serial #xxxxxxxx.
    Ethernet address 0:xx:xx:xx:xx:xx, Host ID: xxxxxxxx.
    {0} ok
Related Information
