If the server is configured with multiple Oracle VM for SPARC domains, use this procedure to shut down the domains and power off the server.
# ldm add-config config-name
The method you use to access a domain depends on how you have configured the consoles for your domains.
To shut down the OS, see Shut Down the OS (init Command) or Shut Down the OS (shutdown Command).
# ldm ls
Note which domains are non-I/O domains or active I/O domains.
# ldm stop-domain domain-name < . . . > # ldm unbind domain-name
# ldm ls
{0} ok #. ->
-> stop /System Are you sure you want to stop /System (y/n)? y Stopping /System ->
