auto-boot-on-error? |
false |
Controls whether or not the host attempts
to boot after POST detects a nonrecoverable error.
auto-boot? |
true |
Controls whether or not the host automatically
boots after a system reset or when the power is turned on.
boot-command |
boot |
Specifies the command to be executed
when auto-boot? is true. Valid
boot commands:
boot – Boots kernel
from devices specified in boot-device.
boot net – Boots kernel
from the network.
boot cdrom – Boots kernel
from the CDROM.
boot disk1:h – Boots from disk 1 partition h.
boot tape – Boots default
file from tape.
boot
device-path – Boots
from the device specified as
device-path. See Locate Device Paths (OpenBoot).
boot-device |
disk net |
Contains the name of the default boot
device that is used when OpenBoot is not in diagnostic mode. |
boot-file |
An optional parameter that provides boot
arguments that are used when OpenBoot is not in diagnostic mode. |
diag-switch? |
false |
If the value is true,
runs in the Diagnostic mode. |
network-boot-arguments |
An optional parameter that enables you
to set configuration parameters to be used by OpenBoot when you
perform a WAN boot. Setting this parameter takes precedence over
any default boot parameter values. Refer to the eeprom(1M)
man page for details. |
