If the server is configured with multiple Oracle VM Server for SPARC domains, use this procedure to power on the server and restart the domains.
-> start /System Are you sure you want to start /System (y/n) ? y Starting /System -> start /HOST/console Are you sure you want to start /HOST/console (y/n)? y
Starting a domain automatically binds the domain.
# ldm start-domain domain-name < . . . >
The method you use to access a domain depends on how you have configured the consoles for your domains.
Boot each domain the same way you boot a server. See Boot the OS (Oracle ILOM).
