SPARC and Netra SPARC T5 Series Servers Administration Guide
Exit Print View
Updated: August 2016
Power Off the Server (Oracle ILOM CLI)
  1. Log in to Oracle Solaris as a user with root privileges.
  2. Shut down Oracle Solaris.
    See one of these procedures:
  3. Switch from the system console prompt to the SP console prompt.
    {0} ok #.
  4. From the Oracle ILOM prompt, type:
    -> stop /System
    Are you sure you want to stop /System (y/n)? y
    Stopping /System
    Note - To perform an immediate shutdown, use the stop -script /System command. Ensure that all data is saved before typing this command.
Related Information
