Understanding the Installation
Understanding Management and Power Cabling
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Configuring the Switching Feature
Configuring the Routing Feature
Check Switch Status (Oracle ILOM)
Note - This procedure is best performed from the SER MGT port. If performed from the NET MGT port, you might lose connection to the SP during the process.
-> cd SP/network
-> set state = state
where state is either enabled or disabled.
Note - If you set the state to disabled, connections to the NET MGT port are lost.
-> set pendingipdiscovery = mode
where mode is either dhcp or static.
Note - By default, the switch uses DHCP as the IP discovery mode.
-> set pendingipaddress=IP_address Set 'pendingipaddress' to 'IP_address'
-> set pendingipgateway=IP_address Set 'pendingipgateway' to 'IP_address'
-> set pendingipnetmask=netmask Set 'pendingipnetmask' to 'n.n.n.n'
The show command displays information about the switch, including its IP address.
For example:
-> show
/SP/network
Targets:
Properties:
type = Network Configuration
commitpending = (Cannot show property)
ipaddress = 10.7.59.97
ipdiscovery = static
ipgateway = 10.7.59.254
ipnetmask = 255.255.255.0
macaddress = 00:14:4f:6C:5D:E8
pendingipaddress = 10.7.59.97
pendingipdiscovery = static
pendingipgateway = 10.7.59.254
pendingipnetmask = 255.255.255.0
state = enabled
Commands:
cd
set
show
-> -> set commitpending=true Set 'commitpending' to 'true'
Note - When you set commitpending to true, connections to the NET MGT port might be lost. You must reestablish connection to the NET MGT port.
