Understanding the Installation
Understanding Management and Power Cabling
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Configuring the Switching Feature
Configuring the Routing Feature
Check Switch Status (Oracle ILOM)
This task tests whether the incoming packets are properly switched on the member ports of the VLAN.
See Connect to SEFOS.
SEFOS-1# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : Ex0/1,Ex0/2,Ex/021,Ex0/22 Untagged Ports : Ex0/1,Ex0/2,Ex/021,Ex0/22 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
# ping -s 20.0.0.20
# ping 20.0.0.10
SEFOS-2# configure terminal SEFOS-2(config)# vlan 101 SEFOS-1(config-vlan)# ports extreme-ethernet 0/1,0/21-22 untagged extreme-ethernet 0/1,0/21-22
SEFOS-2# config terminal SEFOS-2(config)# interface extreme-ethernet 0/1 SEFOS-2(config-if)# no shutdown SEFOS-2(config-if)# end
SEFOS-2# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : Ex0/1,Ex/021, Ex0/22 Untagged Ports : Ex0/1,Ex/021, Ex0/22 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
The ping should be successful.
# ping -s 20.0.0.20 # ping -s 20.0.0.30
