Understanding the Installation
Understanding Management and Power Cabling
Single-Switch Location Guidelines
Attach the Rails to the Switch
Attach Telco Adapters to the Rack Slides
Attach the Rack Slides to the Rack
Install the Switch Into the Rack
Install the Air Duct and Front Support
Attach Data and Management Cables
Prepare the Front Support and Small Air Duct
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From the CLI (SER MGT)
Log Into the Oracle ILOM Web (NET MGT)
Log Into the Oracle ILOM CLI (NET MGT)
Log Into the Oracle ILOM CLI (SER MGT)
Change a SEFOS User Privilege Level
Configure Network Management From the Web Interface
Log Out of the Oracle ILOM CLI
Configuring the SEFOS Environment
Configuring the Switching Feature
Configuring the Routing Feature
Check Switch Status (Oracle ILOM)
See Switching Feature Topology.
Port 1 – Connected to host server A (IP address 20.0.0.10)
Port 2 – Connected to host server B (IP address 20.0.0.20)
Ports 21-22 – Connected to ports 21-22 on the SEFOS-2 switch
See Connect to SEFOS.
SEFOS-1# configure terminal SEFOS-1(config)# vlan 101 SEFOS-1(config-vlan)# ports extreme-ethernet 0/1-2 untagged extreme-ethernet 0/1-2 SEFOS-1(config-vlan)# vlan active SEFOS-1(config-vlan)# exit
SEFOS-1# configure terminal SEFOS-1(config)# interface range extreme-ethernet 0/1-2 SEFOS-1(config-if-range)# switchport pvid 101 SEFOS-1(config-if-range)# no shutdown SEFOS-1(config-if-range)# exit
SEFOS-1# configure terminal SEFOS-1(config-int)# interface vlan 101 SEFOS-1(config-int)# ip address 20.0.0.1 255.0.0.0 SEFOS-1(config-int)# no shutdown SEFOS-1(config-int)# exit
SEFOS-1# show ip interface vlan1 is down, line protocol is down Internet Address is 10.0.0.1/8 Broadcast Address 10.255.255.255 vlan101 is up, line protocol is up Internet Address is 20.0.0.1/8 Broadcast Address 10.255.255.255
SEFOS-1# show interface status Port Status Duplex Speed Negotiation ---- ------ ------ ----- ----------- Ex0/1 connected Full 10 Gbps Auto-Negotiation Ex0/2 connected Full 10 Gbps Auto-Negotiation ... Ex0/4 not connected Full 10 Gbps Auto-Negotiation SEFOS-1# show interface description Interface Status Protocol --------- ------ -------- Ex0/1 up up Ex0/2 up up Ex0/3 down down Ex0/4 down down ... vlan101 up up
The ping should be successful.
SEFOS-1# show mac-address-table Vlan Mac Address Type Ports ---- ----------- ---- ----- 101 00:14:4f:6c:7d:e9 Learnt Ex0/1 Total Mac Addresses displayed: 1
Note - The MAC address displayed must correspond to the MAC address of host A.
To configure the topology, all of the interfaces should be up. If they are not up, use the no shutdown command to bring up the ports.
SEFOS-1# configure terminal SEFOS-1(config)# interface range ex 0/21-22 SEFOS-1(config-if-range)# switchport pvid 101 SEFOS-1(config-if-range)# no shutdown SEFOS-1(config-if-range)# end
In both switches, ensure that the following interfaces are up: 0/1, 0/2, 0/21, 0/22.
