Restore the Configuration
Note -
The administrator must always reset the SNMP engine ID prior to doing the backup or restore operation. Because of CR 6934622, the SNMP engine ID (even when previously set) is not visible after a reset of the system, and the administrator must record and set the ID explicitly.
Configure the network settings on the Oracle ILOM network management interface to communicate with the backup server.
-> cd /SP/network
Set the passphrase to the same value that was used for backup.
See Include the SEFOS Configuration in Backups.
-> cd /SP/config
/SP/config
-> set passphrase=abc123
Set 'passphrase' to 'abc123'
Restore the configuration from the server.
-> set load_uri=ftp://username:password@192.168.1.100/tmp/mySwitchConfig.bak
Load successful.
Note -
If DHCP is used for network configuration, the DNS setting is overwritten with values supplied by the DHCP server upon restoration.
