Download the Switch Firmware Package
After backing up your current configuration, download the newest switch firmware package, for example, Oracle_Switch_ES1-24_sefos-1_3_1_15.pkg.
- Log in to My Oracle Support at:
http://support.oracle.com
- Select the Patches & Updates tab.
- Under the Patch Search section, select Product or Family (Advanced Search).
- Type switch in the Product field and select Oracle Switch ES1-24.
- Select the down arrow in the Release field and select the Oracle Switch ES1-24 folder.
- Select the newest release number.
- Click the Search button.
- Click the number in the Patch Name column.
- Click Download.
- Click the filename of the .zip file to begin the download.
- Save the file to an appropriate location.
- Upgrade the firmware.
See Install the Switch Firmware.
