Reflective relay enables the packet from a device to be returned back from the same downstream port that delivered the packets. The most common use case is when the same interface is used to transmit and receive packets. This usage can be seen while using Virtual Ethernet Packet Aggregation (VEPA).
Refer to the Sun Ethernet Fabric Operating System CLI Base Reference Manual for more information.
