For more information, refer to the Oracle Switch ES1-24 Installation Guide.
The following example illustrates the upgrade process using FTP from a server with an IP address of 192.168.1.100.
-> cd /SP/firmware/
/SP/firmware
-> load -source ftp://username:password@192.168.1.100/Oracle_Switch_ES1-24_sefos-1_3_1_15.pkg
Downloading firmware image. This will take several minutes.
NOTE: An upgrade takes several minutes to complete. ILOM
will enter a special mode to load new firmware. No
other tasks can be performed in ILOM until the
firmware upgrade is complete and ILOM is reset.
Are you sure you want to load the specified file (y/n)? y
Preserve existing configuration (y/n)? y
Starting FW upgrade. This will take approximately 3 minutes.
Checking "root file system image"
Starting Root File System upgrade
Upgrading Root File System image to partition 1
Checking "compressed kernel image"
Starting kernel upgrade
Upgrading image to partition 1
Syncing configuration files
Checking "FPGA image"
Starting FPGA upgrade. This process may take up to 3 minutes.
Programming FPGA image
FPGA upgrade requires SEFOS to be stopped. Please wait while
FPGA is being programmed.
Skip upgrading FPGA (same version).
Checking "U-Boot image"
Starting U-Boot upgrade
Skip upgrading U-Boot (same version).
Firmware update is complete.
The system must be reset for the new image to be loaded
-> reset /SP
Are you sure you want to reset /SP (y/n)? y
Performing reset on /SP
-> cd /SYS/fs_cli cd: Connecting to Fabric Switch CLI ORACLESP-AK00242424 SEFOS# show system information Hardware Version : 2.5.8_00209384 Firmware Version : ES1-24-1.3.1.15 Switch Name : Oracle ES1-24 System Contact : System Location : Logging Option : Console Logging Login Authentication Mode : Local Config Save Status : Not Initiated Remote Save Status : Not Initiated Config Restore Status : Not Initiated
