These requirements must be met to configure in-band management:
In-band and NET MGT networks must be in different subnets.
Configure DHCP on only one of the interfaces. Otherwise, the switch receives two default routes.
Configure one IP gateway only. You can configure the IP gateway using either network management or in-band settings. The IP gateway setting of the other gateway must be set to 0.0.0.0.
On the in-band network, ports used to connect to the switch must be in the default VLAN. No other configuration is required in SEFOS.
