Back Up the Current Configuration Before Upgrading
Save the current configuration to a remote site before upgrading the software. Refer to the Oracle Switch ES1-24 Configuration Guide for additional information.
You can also use the backup and restore feature from Oracle ILOM to save the current Oracle ILOM and SEFOS configurations to a remote server. You can then restore the switch configuration after upgrading the firmware. See Include the SEFOS Configuration in Backups.
Note - During the upgrade, if you answer yes to the question Preserve existing configuration (y/n)?, the Oracle ILOM and SEFOS configurations are automatically preserved. There is no need to explicitly restore the configuration.
- Configure the default IP address.
- Enter Global Configuration mode.
SEFOS# configure terminal
- Configure the default IP address and subnet mask as 10.0.0.100 and 255.255.0.0.
SEFOS(config)# default ip address 10.0.0.100 subnet-mask 255.255.0.0
- Exit Global Configuration mode.
SEFOS(config)# end
- Configure the restoration file name.
- Configure a configuration restoration file name.
SEFOS(config)# default restore-file myconfig.conf
SEFOS(config)# end
- Save the current configuration for restoration.
SEFOS(config)# write startup-config
- Copy the configuration file to a remote location.
SEFOS(config)# copy startup-config tftp://12.0.0.100/switch.conf
- Exit and restart the switch.
SEFOS# exit
-> reset /SP
Are you sure you want to reset /SP (y/n)? y
Performing reset on /SP
- Log in and save the current configuration again before starting the upgrade.
SEFOS# write startup-config
SEFOS# copy startup-config tftp://12.0.0.100/switch.conf
- Download the switch firmware package.
See Download the Switch Firmware Package.
