![]() | Caution - Configure the in-band settings from the serial console to avoid losing access to the switch in case of a misconfiguration. |
ORACLESP-SPNAME login: root Password: password Last login: Wed Oct 3 01:46:55 from hostname.us.oracle.com Oracle(R) Integrated Lights Out Manager (Fabric Component Edition) Version 3.0.16.0 r78530 Copyright (c) 2013, Oracle and/or its affiliates. All rights reserved. Warning: The system appears to be in manufacturing test mode. Contact Service immediately. Warning: password is set to factory default.
-> cd /SP/inband_network/
/SP/inband_network
-> set pendingipaddress=xx.xxx.xxx.xx
Set 'pendingipaddress' to 'xx.xxx.xxx.xx'
-> set pendingipgateway=xx.xxx.xxx.x
Set 'pendingipgateway' to 'xx.xxx.xxx.x'
-> set commitpending=true
Set 'commitpending' to 'true'
-> set state=enabled
Set 'state' to 'enabled'
-> ls
/SP/inband_network
Targets:
test
Properties:
commitpending = (Cannot show property)
dhcp_server_ip = none
ipaddress = xx.xxx.xxx.xx
ipgateway = xx.xxx.xxx.x
ipnetmask = 255.255.255.0
macaddress = 00:xx:xx:xx:xx:xx
pendingipaddress = xx.xxx.xxx.xx
pendingipdiscovery = static
pendingipgateway = xx.xxx.xxx.x
pendingipnetmask = 255.255.255.0
state = enabled
-> cd /SP/network /SP/network -> set state=disabled Set 'state' to 'disabled'
