Cable Direct-Attached Rack Servers (QDR)
In a single-server, direct-attach environment, the Oracle Fabric Interconnects
share an IB fabric by being connected directly. At least two connections are
required for redundancy, but more than two connections can be used for
additional redundancy.
However, using more cables reduces the number of available ports, which
reduces the total number of servers that can be connected. There is no
restriction on which ports on the Oracle Fabric Interconnect connect to which
ports on an IB switch.
Make sure that the subnet manager is shut down and the LID table is
removed.
See Preparing to Merge an IB Fabric (QDR).
Connect a QDR IB cable from one port on the first Oracle Fabric
Interconnect (1) to an IB port on the second Oracle Fabric Interconnect
(2).
Repeat step 2 to create an HA connection between the Oracle Fabric
Interconnects.
These connections provide the merged IB fabric that the two Oracle Fabric
Interconnects share. All other IB ports on each Oracle Fabric Interconnect
can be used to provide connections to host servers in the fabric.
On each host server, connect a QDR IB cable from one server HCA port to an
IB port on the first Oracle Fabric Interconnect (1).
IB port on the second Oracle Fabric Interconnect (2).
At the completion of this step, the Oracle Fabric Interconnects and
servers are connected as shown.
1, 2
Oracle Fabric Interconnect F1-15s (or F1-4s) directly
connected.
3
QDR speed connections (interswitch links, ISLs)
connect the switches together.
4, 5, 6, 7
Host servers with QDR-capable HCAs directly connected
to each switch over QDR links.
Complete merging the fabric.
See Complete the Merged Fabric (QDR).
