In this configuration, each of the Oracle Fabric Interconnects are connected through redundant links to each IB switch. Additionally, each blade-server controller has two connections to each IB switch, and indirectly, to each Oracle Fabric Interconnect.
You can connect two cables to each blade-server controller. However, using two cables reduces the number of available ports, which reduces the total number of servers that can be connected. There is no restriction as to which ports on the Oracle Fabric Interconnect connect to which ports on the controller.
You will need one IB connection to the IB switch for each blade server.
At the completion of this step, each Oracle Fabric Interconnect is connected to the IB fabric through one of the two IB switches. The cross-connection between the IB switches creates the merged fabric.
At the completion of this step, the Oracle Fabric Interconnects and hosts has one or two connections to each controller in each blade server.
Each Oracle Fabric Interconnect has a connection to each blade server through each of the IB switches, and the Oracle Fabric Interconnects are connected in a merged fabric at the IB-switch level. You can use the remaining ports on the IB switches to connect to hosts, and the remaining ports on the Oracle Fabric Interconnects to connect to either IB switches or direct-connected hosts.
