开始之前
在注册 ASR 管理器时,如果需要,键入您的 MOS 单点登录信息和任何代理服务器。
# asr register
1) transport.oracle.com
屏幕输出应类似以下内容:
Proxy server name: ? <proxy server name> Proxy port number: ? <proxy port number> Proxy authentication; if authentication is not required, enter -. Proxy user: <proxy user name> Proxy password: <proxy password> If this is an NTLM type proxy, enter the information below. Otherwise, enter - NTLM Domain: [?] <NTLM domain name> Enter the host the NTLM authentication request is originating from. Usually this is the hostname of the SASM server. NTLM Host: [?] <NTLM host name> NTLM support is not bundled with SASM but may be added now. 1) Download jCIFS from http://jcifs.samba.org/ 2) Extract contents and locate the jcifs-*.jar file 3) Enter full path to this file below jCIFS jar file: [?] <full path of jCIFS jar file> Note: These properties are stored in the /var/opt/SUNWsasm/configuration/config.ini file. You can update these properties if needed and then restart SASM.
您的 MOS 电子邮件地址将接收来自 ASR 问题和服务请求 (Service Request, SR) 生成通知的输出。
