If the server is configured with multiple Oracle VM Server for SPARC domains, use this procedure to power on the server and restart the domains.
-> start /System Are you sure you want to start /System (y/n) ? y Starting /System -> start /HOST/console Are you sure you want to start /HOST/console (y/n)? y
Starting a domain automatically binds the domain.
# ldm start-domain domain-name < . . . >
If a domain's auto-boot? property is set to true, the domain boots the OS after it is started. Domains that do not automatically boot are stopped at the OpenBoot prompt and must be manually booted in the next step.
The method you use to access a domain depends on how you have configured the consoles for your domains.
Boot each domain the same way you boot a server. See Boot the OS (Oracle ILOM).
