Go to main content
SPARC T8 Series Servers Administration Guide
Exit Print View
Updated: September 2017
Enable or Disable Automatic Booting (Oracle Solaris)
While running Oracle Solaris, use this procedure to configure OpenBoot so that a host reset or power on either attempts to boot automatically, or not. This change is permanent but only takes effect after a host reset.
Note - To enable automatic booting of the OS, the Oracle ILOM auto-boot property also must be enabled. You can change the Oracle ILOM auto-boot property at /HOST/domain/control.
  1. Log in to Oracle Solaris and assume the root role.
  2. Set the OpenBoot auto-boot? parameter to true or false using the eeprom command.
    true
    (Default) The host automatically attempts to boot from the devices specified in boot-device.
    false
    The host does not automatically boot. You can boot manually.
    For example:
    # eeprom auto-boot?=false
  3. Verify the change.
    # eeprom auto-boot?
    auto-boot?=false
  4. Reset the host.
    # init 6
    The host resets. After initialization the host attempts to boot or not, based on your configuration.
Related Information
