auto-boot?
true
Controls whether or not the host automatically boots after a system reset or when the power is turned on.
boot-command
boot
Specifies the command to be executed when auto-boot? is true. Valid boot commands:
boot
– Boots kernel from devices specified in boot-device.
boot net
– Boots kernel from the network.
boot cdrom
– Boots kernel from the CD-ROM.
boot disk1:h
– Boots from disk 1 partition h.
boot tape
– Boots default file from tape.
boot
device-path
– Boots from the device specified as device-path. See Locate Device Paths (OpenBoot).
boot-device
disk net
Contains the name of the default boot device that is used when OpenBoot is not in diagnostic mode.
boot-file
An optional parameter that provides boot arguments that are used when OpenBoot is not in diagnostic mode.
diag-switch?
false
If the value is true, runs in the Diagnostic mode.
network-boot-arguments
An optional parameter that enables you to set configuration parameters to be used by OpenBoot when you perform a WAN boot. Setting this parameter takes precedence over any default boot parameter values. Refer to the eeprom(1M) man page for details.
