Create a User Mode Navigator Configuration
You can create one configuration for user mode Project, Shell, or Company Workspace.
To create a project or company workspace navigator configuration:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log lists all previously created configurations.
  3. Click New and choose one of the following:
    • Home: Configures the navigation node for the Master Log - Business Processes node.
      Note: You cannot hide the Tasks, Notifications, Drafts, and Mailbox nodes in the Home workspace.
    • Company Workspace: Configures the navigation nodes within the Company Workspace portion of the User Mode Navigator
    • Project/Shell: Configures the project- or shell-level navigation
    The Create New Navigator window opens. The left portion of the window displays the navigation as it would appear for users. In the example below, the default navigation is displayed, because a new configuration has not been deployed. The right pane of the window displays available modules or business process logs that can be added to the navigation on the left.
  4. Configure the new navigator configuration as described below.
  5. To save the configuration, click OK.
The configuration will be displayed in the log. There can be one configuration each for Project, Shell, or Company Workspace. After saving, you must deploy the configuration for it to take effect. See Deploying a Navigator Configuration.
You can configure the new project or company workspace navigation. After deploying, the configuration will appear in the User Mode Navigator for all users in your company.
Use the toolbar to configure the navigation:
To expand all navigator nodes:
In the navigator window, click the Expand All button. This expands all grouping nodes and lets you view all the nodes currently present in the navigation. You can contract a grouping node to hide the leaf nodes by clicking the (-) next to the grouping node name.
See Also
Configuring the User Mode Navigator
Create a Grouping Node
Rename a Grouping Node
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Delete a Grouping Node
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
