Move Nodes within the Navigator
You can move any grouping node or leaf node up or down the navigator, either within the original grouping node, or from one grouping node to another. There are three ways to move nodes within the navigator:
See the following procedures for more details.
To move a node up or down the navigator:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log opens. The log lists any previously created configurations.
  3. In the navigator window, select the node to move.
  4. Click the Move Up or Move Down button to move the node up or down within the parent grouping node. If you move a grouping node, all child nodes move with it.
To move a leaf node from one grouping node to another:
  1. In the navigator window, select the node to move.
  2. Click the > (right arrow) button to move the node to the right pane. Continue with each node that you want to move.
    Only leaf nodes will be moved. If you select a grouping node, only the leaf nodes underneath it will move to the right pane. The grouping node itself will be deleted.
  3. In the left pane, select the destination grouping node into which you want to move the leaf nodes.
  4. In the right pane, select the leaf node to move and click the < (left arrow) button. The leaf node moves to the grouping node on the left. Repeat as needed with any other leaf nodes to move.
    Note: If you leave a leaf node in the right pane and deploy the configuration, that module or business process will not appear on the User Mode Navigator for users.
To move a node from one grouping node to another by cut and paste:
  1. In the navigator window, select the node to move. You can select a grouping node or leaf node.
  2. Click the Cut button. (The selected node will not yet be removed).
  3. In the left pane, select the destination grouping node in which to move the selection.
  4. Click the Paste button. The node will be moved the new location. If you have selected a grouping node, the grouping node and all leaf nodes will be moved.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Create a Grouping Node
Rename a Grouping Node
Change the Icon of a Grouping Node
Remove Unused Nodes (Modules) from the Navigator
Delete a Grouping Node
Deploying a Navigator Configuration
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
