Delete a Navigator Configuration
If you delete a configuration from the User Mode Navigator log, the system defaults for the applicable portion of the User Mode Navigator (Project, Shell, or Company Workspace) will be restored back to the system defaults automatically.
To delete a configuration and restore the navigator to system defaults:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log opens. The log lists any previously created configurations.
- In the User Mode Navigator log, select the configuration to delete.
- Click the Delete button.
- When the Confirmation message appears, click Yes.
The User Mode Navigator will be restored to system defaults immediately.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Deploying a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
