Create a Grouping Node
You can create a grouping node to use to organize modules or business process logs.
To create a grouping node:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log opens. The log lists any previously created configurations.
  3. Open a configuration from the log.
  4. In the left box, select a valid parent node.
    This can be the root node (Company Workspace, Shell, or Project), or any other grouping node in the navigator tree (for example, Cost Manager or Project Logs).
  5. Click New.
    The newly created node is created under the selected node. The default name is New Grouping Node, and uses the default icon of a file folder. Grouping nodes can be renamed, moved, and given a new icon.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Rename a Grouping Node
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Delete a Grouping Node
Deploying a Navigator Configuration
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
