Deploying a Navigator Configuration
After you have created a navigator configuration, it must be deployed for changes to take effect in User mode. After you deploy the navigation, the view will be displayed to all users.
To deploy a new navigator:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select Configuration, and then select User Mode Navigator.
    The User Mode Navigator log opens. The log lists any previously created configurations.
  3. In the User Mode Navigator log, select the configuration to deploy.
  4. Click the Deploy button.
  5. After the navigation configuration is deployed and a Confirmation message appears, click OK.
The navigator change takes effect immediately for all users.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Create a Grouping Node
Rename a Grouping Node
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Delete a Grouping Node
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
