Delete a Grouping Node
Any grouping node can be deleted. Leaf nodes cannot be deleted; however, you can remove them from the User Mode Navigator that appears to all users. See Remove Unused Nodes (Modules) from the Navigator.
To delete a grouping node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log opens. The log lists any previously created configurations.
- In the left pane of the navigator window, select a grouping node.
- Click the > (right arrow) button. The grouping node is deleted. If the grouping node contains leaf nodes, the leaf nodes are moved to the right pane, and the grouping node is deleted.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Deploying a Navigator Configuration
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
