Remove Unused Nodes (Modules) from the Navigator
If there are nodes (modules) that your company never uses, and that cannot be hidden by use of permission settings (for example, the Mailbox node), you can remove them from the User Mode Navigator. The nodes themselves will not be deleted, and can be restored to the Navigator at any time.
To remove a module from the User Mode Navigator:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log opens. The log lists any previously created configurations.
- In the navigator window, select the node to remove.
- Click the > (right arrow) button to move the node to the right pane. Continue with each node that you want to remove.
Only leaf nodes will be moved. If you select a grouping node, only the leaf nodes underneath it will move to the right pane. The grouping node itself will be deleted.
- Save and deploy the configuration. The nodes that remain in the right pane will not appear in the User Mode Navigator.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Deploying a Navigator Configuration
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
