Change the Icon of a Grouping Node
You can change the icon of any grouping node except the root node (Projects/Shells, Company Workspace).
To change the icon of a grouping node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Configuration, and then select User Mode Navigator.
The User Mode Navigator log opens. The log lists any previously created configurations.
- Open a configuration from the log.
- In the left box, select the grouping node and click the Change Icon button.
The available icons are displayed.
- Click the new icon.
The icon immediately appears on the selected grouping node.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Deploying a Navigator Configuration
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
