Restore the Navigator to Previous or Default Configuration
You can restore the navigator configuration to a previously saved version, the last deployed version, or to original system default at any time. You must still deploy the restored navigator for it to take effect.
To restore the navigator to a previous or default version:
In the configurable navigator window, click the Restore button and choose one of the following options:
- Last Saved: Restores the navigation tree to the last saved version, regardless of deployment
- Last Deployment: Restores the navigator to the version that was last deployed (not applicable for new configurations that have not yet been deployed)
- System Default: Restores the navigator to the original system defaults
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Deploying a Navigator Configuration
Delete a Navigator Configuration
Last Published Tuesday, April 15, 2025
