Rename a Grouping Node
You can rename any new or existing grouping nodes in the left Navigator, with the exception of the root node (Project/Shell or Company Workspace). You cannot rename leaf nodes.
To rename a grouping node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select Configuration, and then select User Mode Navigator. The User Mode Navigator log opens. The log lists any previously created configurations.
- Open a configuration from the log.
- In the left box, double-click the grouping node, or select the node and click the Rename button. The field becomes editable.
- Enter a new name for the field, up to 32 characters. Grouping nodes under same parent node cannot have same name.
See Also
Configuring the User Mode Navigator
Create a User Mode Navigator Configuration
Change the Icon of a Grouping Node
Move Nodes within the Navigator
Remove Unused Nodes (Modules) from the Navigator
Deploying a Navigator Configuration
Delete a Navigator Configuration
Restore the Navigator to Previous or Default Configuration
Last Published Tuesday, April 15, 2025
