Oracle Field Service and ESRI ArcGIS Field Maps Configurations for ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Setup Guide
Preface
Audience
Documentation and Resources
Updates to Documentation
Documentation Accessibility
Conventions
Acronyms
Introduction
ESRI ArcGIS Field Maps to Oracle Field Service Integration Overview
ArcGIS Artifacts
Prerequisites
Required Software
Feature Layers
Feature Class and Feature Layer
Tasks Feature Class and Feature Layer
Attribute Domains
Contingent Values
Using the Task Feature Layer
Activities Feature Class and Feature Layer
ActivityAssets Table
Using Activities and ActivityAssets
ArcGIS Pro Configurations
About ArcGIS Pro
Creating Database Connection in ArcGIS Pro
Creating Server Connection
Configuring and Deploying the Task Feature Layer
Importing the Tasks Workspace Document
Verifying the Schema
Updating Domains
Updating Contingent Values
Adding the Task Feature Class to Map
Publishing Feature Class on ArcGIS Online
Publishing Feature Class on Standalone ArcGIS Enterprise Server
Adding the Activities Feature Layer to Webmap
Enabling Offline Capability
Configuring and Deploying the Activities Feature Layer
Importing the Activities Workspace Document
Adding the Activities Feature Class and ActivityAssets Table to Map
Creating Forms
Creating a Work Order/Work Request Form using Webmaps
Creating Popups
Configuring Popups on Asset Feature Layers
Arcade Expressions
Configuring Popups on Activity Feature Layers
Adding Field Information
Arcade Expressions
Updating Domain and Contingent Values
Regenerating CSV Files
Updating on Standalone ArcGIS Enterprise Server
Updating on ArcGIS Online
Configuring the Oracle Field Service Plugin
Oracle Field Service and ESRI ArcGIS Field Maps Configurations for ESRI ArcGIS Field Maps Integration to Oracle Field Service Mobile Release 24C Setup Guide
