Item - Characteristics
The characteristics page contains information that describes miscellaneous information about the item. Use and navigate to the Characteristics page to maintain Item information.
Description of Page
Item Info is a concatenation of the item's item type, badge number and status.
Item ID is the system-assigned random number that stays with an item for life. This value only appears after the item exists on the database.
To modify a characteristic, simply move to a field and change its value. To add a new characteristic, click the + button to insert a row, then fill in the information for each field. The following fields display:
Effective Date Indicate the date on which the characteristic value becomes effective. The item's date received defaults.
Characteristic Type Indicate the type of characteristic.
Characteristic Value Indicate the value of the characteristic.
Default note. If the item's item type has required characteristics, the respective characteristic types will default in the above grid.
