Meter - Meter ID
A meter may have alternate ID's other than its badge number. If it does, each alternate form of ID is defined using the and navigate to the Meter ID page.
Description of Page
To modify a meter ID, simply move to a field and change its value. To add a new alternate form of identity, click + to insert a row, then fill in the information for each field. The following fields display:
Meter ID Type Indicate the type of meter ID.
Meter ID Number Indicate the alternate meter id.
Where Used
The data on this page is used by the meter read upload process to identify the meter configuration that is being read. Refer to Uploading Meter Reads for more information.
