Meter Replicator - Meter
The Meter page is a display-only page provided to let you confirm that the meter you selected is the one to be used as the template by the replicator. Use and navigate to the Meter page.
Some equipment may not be copied. Equipment that is linked to the template meter will NOT be replicated on the replicated meters if the equipment references an item type that does NOT permit multiple equipment assignments. Refer to The Big Picture of Meters, Items and Equipment for more information about equipment linked to meters.
Description of Page
This is a display-only page that displays information about the registers linked to the meter identified in the add dialog. Refer to Meter - Main Information for a description of the fields.
