Look For Orders That Have Slipped Through The Cracks
Occasionally, you should use the Field Order Search to check if any field orders have been pended by operator for too long. You see, if a user appends a field order, at some point they need to either cancel it or dispatch it. If they don't, the order will sit in limbo forever.
You should also use this query to check for work done, not recorded orders in case someone forgot to complete them.
