Interval Pricing Details - Main
To navigate to this page, you must first go to and display a bill segment with interval data in its calculation lines. From the Calc Lines tab, you may choose to audit a bill line that is the result of an interval pricing rate component that has an audit algorithm. Choosing the drill down button for an interval pricing calculation line will bring you to the Interval Pricing - Calc Details - Main page.
Description of Page
Identifiers and descriptions are shown for the Account, SA and Premise linked to this bill segment.
The Bill Seg ID, Bill Seg Header and Calc Line identify the bill calculation line currently displayed. The Description on Bill displays the description of the bill line that is printed on the customer's bill.
The date and time covered by the Consumption Period are displayed.
Refer to Bill Period and Seasonal Time Shifts for more information.
The Quantity Billed displays the quantity, followed by a description of the unit of measure, followed by a description of the SQI, if applicable.
The Total Amount of the bill line is displayed, followed by the date and time this line was Calculated On.
If you click Rate Info, a dialog opens displaying information about the rate. The information includes the rate schedule and version, the rate component sequence and description, the interval profile relationship type and bill factor information.
The Start Date/Time and End Date/Time indicate the range of the data that is currently displayed. To limit the amount of data displayed, enter a different start and end date and time and click Zoom. Use Refresh to display all the data linked to the bill segment calculation line.
The Interval Billing Graph displays three sets of data and uses color to distinguish between them. Red is used for the interval quantities. The Y-axis shows the range of values plotted under the column UOM. Blue is used for the prices that are coming from the interval billing factor values. The Y-axis shows the range of values plotted under the column Price. Green is used for the resulting calculation at each interval of quantity multiplied by price. The Y-axis shows the range of values plotted under the column Cost. For all three curves, the X-axis shows the date for each interval.
Controlling Which Graphs Are Displayed
All three sets of data are displayed initially, however, you may control which sets of data are displayed by clicking the UOM, Price, or Cost legend markers on the top of the interval graph. For example to view only the Price graph, click the UOM and Cost legend markers.
To redisplay the UOM and Cost graphs, click the respective legend markers again.
Drilling Down In the Graph
While the graph is displayed, you may click a group item (such as, the a date on the x-axis) to drill down into more detail. For example, clicking the group item will drill down to a small number of days.
You can display hour-by-hour information by clicking further.
At this point, if you click on one of the bars, you will be taken to the appropriate interval data set page to view the interval data itself.
