TOU Data Set
You must create a data set for each batch of records being uploaded in the system for the same classic TOU Map. The name of this table is CI_​TOU_​DATA_​SET. The following table describes each column on this table.
Column Name
Length
Req'd
Data Type
Comments
TOU_​DATA_​SET_​ID
12
Y
A/N
This is a unique key. This key is referenced on the TOU Data record.
It's suggested that this key is built as follows:
  • The first five digits are the first five digits of the TOU MAP_​ID.
    • The last seven digits are randomly generated.
      This facilitates set based processing of the data. If your process that inserts records on this table is capable of calling a routine, call ProgramCIPZKEYG passing the first five digits and it supplies a seven-digit random number.
TOU_​MAP_​ID
12
Y
A/N
This is a foreign key reference to the classic TOU map to which this set is linked.
Refer to Classic TOU Map Maintenance for more information.
SET_​DTTM
26
Y
DateTime
This is the date/time that the data set was received. This must be populated with the current date/time. This is considered a server date and follows the seasonal time shifting as defined on the base time zone. Refer to Seasonal Time Shifts for more information.
Refer to Algorithms Find the Most Up-To-Date Data for information about why this date/time is important.
