Extract Miscellaneous Fields From The Eligibility Rules
During this step, you extract miscellaneous fields that must be captured on the order in order drive your eligibility rules.
Misc. Field |
Where Stored |
Why Is It Needed |
Date of birth |
Person characteristic |
Numerous eligibility rules use this field to determine if a customer is a senior citizen |
Type of Residence |
Premise characteristic |
Numerous eligibility rules use this field to qualify a customer for a package |
Type of Heat |
Fields explicitly referenced on every order. You'll notice that we didn't list those fields referenced in the eligibility rules that are explicitly referenced on every order (e.g., customer class, state, division, etc.). This is because these types of fields come "for free".
