Widget Names
When embedding widgets, use the following widget names:
| Feature | Widget Names |
| Account Center |
widget-communication-preferences
| Affordability Savings Hub | For the authenticated workflow, you must use widget-lmi-survey-programs, and define the opower-instance to embed the survey questions on an authenticated webpage. The webpage must exclude footers and side navigation panels. The full embedded tag is: For the pre-authenticated workflow, follow the same steps but embed the survey questions on a pre-authenticated webpage. The full embedded tag is: |
| Bill Comparison |
widget-bill-compare-enhanced
| Bill or Usage Forecast |
widget-bill-forecast
| Bill Guide |
widget-bill-guide
| Business Profile | widget-business-profile
The same |
| Confirmation Message |
widget-bite-sized
| Data Browser |
widget-data-browser
| Demand Heatmap |
widget-demand-heatmap
| Energy Use Overview |
widget-usage-overview
| Green Button |
widget-usage-export
| Guest User Access |
widget-guest-user-access
| Highest Energy Use Days |
widget-highest-day-of-use
| Home Energy Analysis v1 - Authenticated Workflow |
For the survey questions, you must use
widget-survey, and define the opower-instance to embed the survey questions on a separate webpage. This webpage must exclude footers and side navigation panels. The full embedded tag is:For the pre- and post-survey experience, you must embed both <opower-widget-survey opower-instance="widget-survey-splash"></opower-widget-survey> |
| Pre-Authenticated - EasyOpen Workflow - Pre-Authenticated Workflow |
You can allow customers to access the survey without logging in to their utility account. For the survey questions, you must use
widget-survey to embed the survey questions on a separate webpage. This webpage must exclude footers and side navigation panels. The full embedded tag is:For the pre and post survey experience you must embed both
widget-survey and widget-disaggregation together on the same webpage. Only one experience is displayed to customers at a time. The full embedded tags are: |
| Home Energy Analysis v2 - Authenticated Workflow |
widget-survey, and define the opower-instance, to embed the survey questions on a separate webpage. This webpage must exclude footers and side navigation panels. The full embedded tag is:For the pre and post survey experience you must embed both
widget-survey and widget-usage-categories together on the same webpage, and define the opower-instance attribute as part of the embedded tag. Only one experience is displayed to customers at a time. The full embedded tags are:<opower-widget-usage-categories opower-instance="widget-usage-categories"></opower-widget-usage-categories> |
widget-survey and widget-usage-categories together on the same webpage. Only one experience is displayed to customers at a time. The full embedded tags are: |
| Home Energy Analysis Call-to-Action |
widget-hea-cta
| Home Energy Analysis Light |
widget-usage-categories-overview
| Mini Bill Comparison | widget-mini-bill-compare |
| Neighbor Comparison |
widget-neighbor-comparison
| Next Best Action |
widget-next-best-action
| Peak Time Rebates |
widget-peak-time-rebate
| Portfolio View |
widget-portfolio-view
| Rate Comparison |
widget-rates
| Rates Light | widget-rates-light |
| Near Real Time Usage | widget-real-time-ami |
| Solar Savings Insight |
widget-solar-savings
| Solar Welcome Experience - How Solar Works |
widget-how-solar-billing-works
| Tips Light |
widget-tips-light
| Tips List |
This widget is part of the Ways to Save widget. This widget can be configured to display the Tips List user experience by default rather than the Ways to Save experience. |
| Ways to Save |
widget-ways-to-save
