Confirming Switch Specifications
Preparing to Install the Switch
Install the Switch in the Rack
Finish the Switch Installation
Connecting to the Service Processor
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Configuring SEFOS User Privileges
Change a SEFOS User Privilege Level
Check Switch Status (Oracle ILOM)
SEFOS is a full-featured fabric and switch management software package for configuring and monitoring the switch’s network infrastructure.
When creating Oracle ILOM user accounts, an Oracle ILOM user with user management privileges can select which fabric/switch privilege level to give that user account. The fs_privilege attribute determines which administrative tasks that user can perform from the SEFOS CLI. The privilege levels are currently 1 and 15. Level 1 allows read-only and level 15 allows full administrative rights.
You can explicitly declare the fs_privilege attribute when you create a user account, or a root user can change the attribute at any time. By default, a new Oracle ILOM user account is given an fs_privilege level of 1.
Note - The fs_privilege attribute is configurable from the SEFOS CLI only. This attribute is viewable from the web interface.
