Confirming Switch Specifications
Preparing to Install the Switch
Install the Switch in the Rack
Finish the Switch Installation
Connecting to the Service Processor
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Configuring SEFOS User Privileges
Change a SEFOS User Privilege Level
Check Switch Status (Oracle ILOM)
See Front Panel Components for the location of the serial management port on the switch.
This action establishes the connection between the terminal device and the switch Oracle ILOM.
The Oracle ILOM login prompt appears.
SUNSPnnnnnnnnnn login:
The default user is root and the default password is changeme.
The Oracle ILOM prompt appears.
-> cd SP/network
Note - By default, the switch uses DHCP as the IP discovery mode. To use static as the IP discovery mode, use the following command.
-> set ipdiscovery = static
-> set pendingipaddress=n.n.n.n Set ’pendingipaddress’ to ’n.n.n.n’
For example:
-> set pendingipaddress=10.7.59.97 Set ’pendingipaddress’ to ’10.7.59.97’
-> set pendingipgateway=n.n.n.n Set ’pendingipgateway’ to ’n.n.n.n’
For example:
-> set pendingipgateway=10.7.59.254 Set ’pendingipgateway’ to ’10.7.59.254’
-> set pendingipnetmask=n.n.n.n Set ’pendingipnetmask’ to ’n.n.n.n’
For example:
-> set pendingipnetmask=255.255.255.0 Set ’pendingipnetmask’ to ’255.255.255.0’
-> set commitpending=true Set ’commitpending’ to ’true’
-> set state=enabled Set ’state’ to ’enabled’
-> show
The CLI displays information about the switch, including its IP address.
For example:
-> show /SP/network Targets: Properties: type = Network Configuration commitpending = (Cannot show property) ipaddress = 10.7.59.97 ipdiscovery = static ipgateway = 10.7.59.254 ipnetmask = 255.255.255.0 macaddress = 00:14:4f:6C:5D:E8 pendingipaddress = 10.7.59.97 pendingipdiscovery = static pendingipgateway = 10.7.59.254 pendingipnetmask = 255.255.255.0 state = enabled Commands: cd set show ->
-> exit
Log into Oracle ILOM web.
Log into Oracle ILOM CLI.
