Skip Navigation Links
Exit Print View
Sun Network 10GbE Switch 72p
User’s Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Switch
Switch Overview
Front Panel Components
Rear Panel Components
Confirming Switch Specifications
Physical Specifications
Electrical Specifications
Environmental Specifications
Acoustic Noise Emissions
Installing the Switch
Preparing to Install the Switch
Verify Shipping Kit Contents
Antistatic Precautions
Install the Switch in the Rack
Connecting Management Cables
Management Cable Requirements
NET MGT Port
Connect the NET MGT Cable
SER MGT Port
Connect the SER MGT Cable
Powering On the Switch
Power Cord Specifications
Power On the Switch
Connecting Ethernet Cables
QSFP Cables
SFP+ Cables
Splitter Cables
Ethernet Cable Cautions
Connect Ethernet Cables
Finish the Switch Installation
Administering the Switch
Connecting to the Service Processor
Oracle ILOM Overview
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Log Out of ILOM
Configuring SEFOS User Privileges
Create a SEFOS User
Change a SEFOS User Privilege Level
Update the Firmware
Connecting to SEFOS
SEFOS Overview
Connect to SEFOS
Disconnect From SEFOS
Servicing the Switch
Troubleshooting the Switch
Identifying LEDs
Front Panel LEDs
Rear Panel LEDs
Sensors Overview
Check Switch Status (LEDs)
Check Switch Status (Oracle ILOM)
Component Sensor Targets
Motherboard Sensor Targets
Tools Needed for Service
Replaceable Components
Servicing Power Supplies
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Remove a Fan
Install a Fan
Servicing Ethernet Cables
Remove an Ethernet Cable
Install an Ethernet Cable
Servicing the Battery
Remove the Battery
Install the Battery
Glossary
Index
  1. Log into Oracle ILOM.
    See Connecting to the Service Processor.
  2. Display the status of parameters of chassis components or the motherboard.
    -> show target
    where target is the Oracle ILOM target name of the component or motherboard sensor in Component Sensor Targets or Motherboard Sensor Targets.
    For example, to display the speed of Fan 0, type.
    -> show /SYS/FM0/SERVICE
     /SYS/FM0/SERVICE
     Targets:
     Properties:
         type = Indicator
         ipmi_name = FM0/SERVICE
         value = Off
