Confirming Switch Specifications
Preparing to Install the Switch
Install the Switch in the Rack
Finish the Switch Installation
Connecting to the Service Processor
Oracle ILOM Features Not Supported
Verify the DHCP-Assigned IP Address and Host Name
Configure Network Management From CLI (SER MGT)
Log Into Oracle ILOM Web (NET MGT)
Log Into Oracle ILOM CLI (NET MGT)
Log Into Oracle ILOM CLI (SER MGT)
SER MGT Port Configuration Parameters
Configure Network Management From Web
Configure Network Management From CLI (NET MGT)
Configuring SEFOS User Privileges
Change a SEFOS User Privilege Level
Check Switch Status (Oracle ILOM)
Note - When you install the Ethernet cables, connect cables to the lower connectors first, then connect cables to the upper connectors.
See:
The shell should not be bent and should be parallel to the inner boards. If the connector is bent or damaged, use a different cable.
Some optical transceiver modules are dual-part assemblies, where the module and the cable are two separate pieces, while other optical transceiver modules are single-part assemblies, where the module and the cable are a single combined unit.
If you are installing a dual-part module, go to Step 8.
If you are installing a single-part module, go to Step 9.
The following figure shows the correct alignment for the transceiver module.
Note - If you pull the locking handle down when the SFP+ or QSFP optical transceiver module is installed, you should remove the optical transceiver module entirely and reinstall it. The handle operates an internal lock. Pulling the handle down can disconnect the module, even though it might appear to be connected.
Esure that the L groove is up for the top row of receptacles, or that the L groove is down for the bottom row of receptacles.
Note - The optical tranceiver handle must be closed before attaching the cable to the tranceiver. The handle locks the tranceiver in place in the switch port.
If you are plugging in a fiber dual-part cable assembly (transceiver and cable separate), verify that the handle is in the locked position and connect the cable to the optical transceiver. If the handle is in the unlocked position, you must push it up into the locked position before attaching the cable.
If you are plugging in a single-part assembly, slowly slide the connector into the receptacle.
As you slide the connector in, the top of the shell should scrape against the underside of the top of the receptacle.
If the cable stops or binds after about 1/4 in. (5 mm) travel, back out and repeat.
If the connector stops or binds with about 1/8 in. (2 mm) still to go, back out and repeat.
Use hook and loop fastener straps to bundle and secure the cables.
Note - Do not use cable zip ties to bundle or secure the cable, because the ties damage the wires inside the cable.
If the Link LED is off, the link is down. If the Link LED flashes, there are symbol errors. See Front Panel LEDs.
